1994 volvo 850 turbo wagon - ptc valve
southofmotown
- Year and Model: 1994 850 turbo
Can anyone tell me what this hose is (outlined in yellow)? I have it connected my PTC valve, which I assume is proper placement. Thanks.
- Has thanked: 1836 times
- Been thanked: 1709 times
From your other post, this pipe should run to the RH end of the inlet manifold and is the smaller pipe of the 2 you show in the other post. (RH is passenger side just behind the rear of the power steering pump and alternator.
southofmotown
So bottom line is it should NOT be connecting to the PTC valve?
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
ONLY the 2 hoses in the foam sleeve should be connected to the PTC. The big one on top, and the one with the elbow on the connection in your first pic.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
southofmotown
Sommerfeldt
Well... there should be a connector for it. I can see that you don't have one... But it would be helpful to see what connections you have on the other side. Have someone been tinkering with you intake manifold, to your knowledge?
Anyway, seems this chap has the same problem you do, if I'm not mistaken: http://volvoforums.com/forum/volvo-850- ... ump-24402/
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The vehicle is a '94 model and probably has tubes running along the top of the head under the spark plug cover. Different from most.
Sommerfeldt
Yeah...could be. But isn't it still supposed to have the manifold connector? To me it kind of looks like someone's put a plug in that whole side of the manifold.rspi wrote:The vehicle is a '94 model and probably has tubes running along the top of the head under the spark plug cover. Different from most.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
southofmotown
No I can't see that anyone has tinkered with the intake manifold - it was owned by a lady and then a younger guy who I don't think did much maintenance. As far as Robert's explanation, I've attached a pic of under the spark plug cover (if this view is helpful). Also, there is a hose that I don't know where it connects. I've outlined it in red so you can follow it. Can you tell me what it is and where it should connect? Thanks.
- Has thanked: 1497 times
- Been thanked: 3810 times
Can you put up a picture of your vacuum hose diagram..sticker under the hood?
What's left....
EGR?
Fuel pressure regulator
Evap purge valve
What's left....
EGR?
Evap purge valve
- 14 Replies
- 2300 Views
- 1157 Views
Last post by 98v70xc206
