2004 volvo xc90 steering is hard and pulling to the right
deandde
Year and Model: 2004 xv90
Post by deandde »
my steering is very hard to maneuver and pulling to the right, what caused that to happen?
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Bad rack, tie rod end, ball joint, strut bearing.. I would put it on jack stands take the wheels off and disconnect the tie rod ends and see if the wheels turn independently fine and go from there.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Might be two different issues. Depends how hard does it pull. If you keep the steering wheel right at the center on highway, does the car go straight? Tire pressure is equal in front? Tire wear is normal?
For the hard to turn, I would suspect the lower coupler for having seized, in the first place.
If that checks fine, the power steering pumps do wear in time (refurbished ones are not much better). The fluid must be the green one. The top strut bearing also can wear and make the steering hard.
