1982 volvo Automatic transmission?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 26 times
Re: 1982 volvo Automatic transmission?
Post by lummert »
According to www.volvoclub.org.uk
Use Dexron fluid in your AW or ZF transmission. The latest Dexron spec is III-H and it is backward compatible to the Dexron II and III listed in the owners Manual.
1988 Volvo 760 Turbo Wagon
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
vintagevolvo wrote:1982 Volvo GLT 244 ...Unfortunately, I don't have the original manual that came with the vehicle.
Volvo Owner's Manuals
jimmy57
Been thanked: 320 times
Post by jimmy57 »
1982 uses Type F.
Rear drive auto trans Volvos to 1983 except those with ZF gearboxes (not your 240) use Type F.
ZF any year and 1984 and later rear drives uses Dexron (now dexron/mercon) fluid.
Dexron should be avoided in Type F gearboxes. The internal seals and friction parts are the same but the accumulators and valve body pressure regulator springs are for lower pressure and slower pressure build for F fluid due to its aggressive friction modifiers. Dexron gearboxes have faster pressure build due to a friction modifier additive package that smooth shifts by allowing some clutch slip but requires faster ramp up of pressure to avoid the slip causing too much wear.
Dexron in F type trans is bad, F in Dexron trans causes harsh shifts but rarely any issues. F type in a GM or CHrysler trans designed for Dexron was a 60's/70's/80's racer trick for slip reduction before the transmissions went to adaptive electronic controls.
If your car has happened to have had a trans replacement to a later year build then it will have a drain plug and the plug will have "D-II" on it. Through 1983 the AW70/71 did not have drain plugs (you unscrewed the filler pipe from pan to allow it to drain on those).
93Regina
Post by 93Regina »
jimmy57 wrote:1982 uses Type
Capacity: (with overdrive) 7.8 US qts = 7.4 liters
(without overdrive) 7.1 US qts = 6.7 liters
Fluid type: Automatic Transmission Fluid type G(FLM).
CASTROL Transmax Type F
For automatic transmissions requiring Type F or G fluids. Formulated to satisfy the special friction requirements and wear resistance of Ford M2C-33F or G specifications to ensure transmission durability.
lummert
Post by lummert »
NAPA carries type FA fluid as a type F replacement.
93Regina
Post by 93Regina »
vintagevolvo wrote:Pennzoil Type F ATF
Key-nomenclature - M2C-33, which is the G specification for Type G
Pennzoil® Type F - Meets or exceeds the requirements of Ford Motor Company specification M2C33F
93Regina
Post by 93Regina »
vintagevolvo wrote:Canada?
Car Care > Car Parts > Fluids & Filters > Transmission Fluid - Type F (FLM) is a specially compounded fluid meeting the latest Ford ESW-M2C33F and is compatible with all M2C33 series Ford specifications.
Valvoline™ Type F - It is designed for use where Ford specifications M2C33-F, M2C33-G and Ford Type F fluids are recommended.
Motorcraft® Type F Automatic Transmission Fluid (ATF) - Special frictional properties help ensure proper shifting in Ford transmissions that require a fluid meeting ESW-M2C33-F
CASTROL Transmax Type F - For automatic transmissions requiring Type F or G fluids. Formulated to satisfy the special friction requirements and wear resistance of Ford M2C-33F or G specifications to ensure transmission durability.
