04 XC70 Has anyone else experienced this?
Its not really a problem but over the last two years my car has been discharging the glass packing from the resonator out the tail pipe. I think last night it made its final discharge as a two huge hairballs were left in the road after a downshift going up a steep hill. It looked like I had run over two raccoons. The exhaust tone or volume has not changed a bit nor has any other aspect of the car. Although I may notice a slight increase in power, probably a 0.06% gain in hp at 6,000 rpm (this would be a significant improvement if we were talking about Hondas). Just curious if anyone else's has done this? I have never seen it happen before but apparently GM vehicles are known for it.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe some rodent made his home inside the muffler?
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Been thanked: 3 times
Back in the day, truck-necks found this desirable. One would buy a 'cherry bomb', saturate the "witch's hair" with gasoline and rev it until the cherry bomb gave up it's ghost. Loud but still had the regulatory muffler.
I'm thinking rodent nest in muffler... unless you've noticed a bark at certain RPM/power ranges. If the noise has increased as described, then it would be the resonator internal dampening. Automakers install resonators (basically a mini-muffler 'glasspack') to dampen 'undesirable' exhaust tones.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
It is definitely not a rodent nest. It is fiberglass, you can see right into the resonator with a light. There is no noticeable sound difference.
2004 XC70
- 18 Replies
- 2701 Views
Last post by Volvalive
- 762 Views
Last post by oragex
- 9 Replies
- 7665 Views
Last post by enriquepr21
- 33 Replies
- 11390 Views
- 34 Replies
- 6463 Views
Last post by June
