Documenting this on my 1999 T5
I recently replaced my passenger side front wheel bearing and broke the ABS sensor wire during the job. I drove the car for a few days with the bad ABS sensor (ABS light and CEL P1550 code showing) and noticed a profound bogging at low rpm. There was about a 1/2 second delay to throttle response when accelerating. The way I usually drive I didn't notice it but if I tried to mash the pedal it really showed.
Im not sure if the ECU was remapping due to the lack of vehicle speed sensor (VSS) info or if perhaps I had reset the map clearing the codes when I diagnosed the problems. Im thinking away from the latter explanation, as the minute I fixed the ABS sensor and cleared codes, the bog disappeared.
My AUTEL unit reported P1550 as a compressor boost mismatch or some gibberish like that - I was worried something was up with my turbo for a few minutes. When I researched, I found that the Volvo P1550 was indeed related to VSS
P80 Driveability observation - ABS wheel sensor failure
- Has thanked: 1614 times
- Been thanked: 4078 times
- 72 Replies
- 22853 Views
Last post by mrbrian200
- 1027 Views
Last post by sleddriver
- 1940 Views
Last post by misha
- 18 Replies
- 4376 Views
Last post by aaus3736
- 17 Replies
- 6536 Views
Last post by ignatz
