need advice on this problem oil fouling on 1 spark plug,,,i had a crank pressure which i sorted out but still getting a bit of a blow back from the dip stick,if 1 of the piston rings is worn could this cause oil fouling on the plugs or is the oil fouling down to worn valve stem seals,it only happens when i rev the engine and seems to stop after the engine gets hot but then that could be down to the plugs burning off the oil on the plugs,,the valve stem seals can thay be replaced with out removing the head any help plz,,,
the car is volvo 850 2.5 10valve yr 1994
got the garage to do a compression test today the test was
cylinders(1)=180 (2)=180 (3)=180 (4)=190 (5)=185
now im not sure if this is bad or good,any ideas if there is something wrong
cheers joe
