Unfortunately, I am having to part out this 2000 Volvo S80 T6. Hopefully some of you can put some of this stuff to use!
Car is black with neutral gray interior.
I figured the best way to do this would just kind of put parts and prices as I go along on disassembling the car.
If you have any questions or need anything, just post up below. As I am able to pull more parts, I'll post them up!
I tried to be reasonable with the pricing, but if I am not - PM me and let me know.
Buyer responsible for all shipping costs - Located at ZIP 70510 (just south of Lafayette, Louisiana)
Fuel Rail with Injectors - $45
Undamaged Intake Accordion Hose - $20
Mass Airflow Sensor - $20
Intake hardpipe from Accordion Hose to Turbo Inlet pipes - $30
2 into 1 Intake Pipe from Turbo Compressor to Intercooler (Includes the Twin Charged metal plate) - $20
Exhaust Camshaft CVVT Valve - $20
5 Coils (6th connector broke, threw it away) - Definitely used, all for $15
Starter - Tested Good on 2 Different Test Benches - $35
Taillight Pair - $70
Underhood Fuse/Relay Unit (PN# 9494207-petrol) - $40
includes the following relays:
2x 9441158 / 2x 9441160 / 4x 9441161
Grille (Mounting tabs intact!) - Fits Years 1999-06 - $35
Cooling Fan - PN# 0130303909 - $75
Engine Computer - PN# 0261206272 or 09470738 B - $20
TCM - PN# P09472349 - $15
A/C Compressor - System was blowing cold air and was full of refrigerant prior to disassembly - $50
ABS Module - Car did not throw an ABS code, however, I always consider these to be cores! - $40
Set of 4 Wheels - Will Remove Tires for Shipping - $300
Keyfob - $8 shipped
Brake master cylinder with resevoir - $20
Exhaust manifolds and turbos. I would consider these cores but only one has significant shaft play. As pictured $100
Turbo compressor piping - in and out. $25
Steering Wheel - $15
Gear Selector Unit - $20
Airbags (Drivers side has cruise control switches) - $45
Gray Dashboard - $50 (either pickup only, or i will bring it to a crating shop - buyer will be responsible for packaging costs and shipping costs)
Please let me know if there is something you might be in need of as well!
