Breaking/Parting Out - 2000 Volvo S80 T6 (Black/Gray) - Louisiana
Gumbeaux
Year and Model: 2000 S80
Post by Gumbeaux »
Hey guys -
Unfortunately, I am having to part out this 2000 Volvo S80 T6. Hopefully some of you can put some of this stuff to use!
Car is black with neutral gray interior.
I figured the best way to do this would just kind of put parts and prices as I go along on disassembling the car.
If you have any questions or need anything, just post up below. As I am able to pull more parts, I'll post them up!
I tried to be reasonable with the pricing, but if I am not - PM me and let me know.
Buyer responsible for all shipping costs - Located at ZIP 70510 (just south of Lafayette, Louisiana)
Fuel Rail with Injectors - $45
Undamaged Intake Accordion Hose - $20
Mass Airflow Sensor - $20
Intake hardpipe from Accordion Hose to Turbo Inlet pipes - $30
2 into 1 Intake Pipe from Turbo Compressor to Intercooler (Includes the Twin Charged metal plate) - $20
Exhaust Camshaft CVVT Valve - $20
5 Coils (6th connector broke, threw it away) - Definitely used, all for $15
Starter - Tested Good on 2 Different Test Benches - $35
Taillight Pair - $70
Underhood Fuse/Relay Unit (PN# 9494207-petrol) - $40
includes the following relays:
2x 9441158 / 2x 9441160 / 4x 9441161
Grille (Mounting tabs intact!) - Fits Years 1999-06 - $35
Cooling Fan - PN# 0130303909 - $75
Engine Computer - PN# 0261206272 or 09470738 B - $20
TCM - PN# P09472349 - $15
A/C Compressor - System was blowing cold air and was full of refrigerant prior to disassembly - $50
ABS Module - Car did not throw an ABS code, however, I always consider these to be cores! - $40
Set of 4 Wheels - Will Remove Tires for Shipping - $300
Keyfob - $8 shipped
Brake master cylinder with resevoir - $20
Exhaust manifolds and turbos. I would consider these cores but only one has significant shaft play. As pictured $100
Turbo compressor piping - in and out. $25
Steering Wheel - $15
Gear Selector Unit - $20
Airbags (Drivers side has cruise control switches) - $45
Gray Dashboard - $50 (either pickup only, or i will bring it to a crating shop - buyer will be responsible for packaging costs and shipping costs)
Please let me know if there is something you might be in need of as well!
Gumbeaux
Post by Gumbeaux »
Pulled the transmission tonight.
Although the car shifted from 1st to 2nd well enough, I was never able to get the car out on the road for a test drive.
As such I am selling this as a CORE transmission.
I would be willing to ship directly to a rebuilder on your behalf - so if you wanted to do a Triple Edge transmission rebuild, I could send it to them if you've made prior arrangements.
Asking 300 dollars plus shipping for the core trans (2000 T6 - 4T65EV-GT)
Gumbeaux
Post by Gumbeaux »
Here you guys go - moar stuf!
Ignition Switch - $15
Clockspring - $15
Airbag Module - $15
Wiper/Turn sig stalk assembly - $25
Climate control panel (note broken mounting tab) - $20
Gumbeaux
Post by Gumbeaux »
RH hub assembly - $20
RH Front Caliper Brackets - $15
T6 halfshafts - $45
Gumbeaux
Post by Gumbeaux »
CVVT Solenoid sold.
jcdillin
Year and Model: 06 V70R
Been thanked: 3 times
Post by jcdillin »
Did this car have the audio amp under the passenger seat?
Gumbeaux
Post by Gumbeaux »
I havent yanked the seats yet but I will check this evening!
Gumbeaux
Post by Gumbeaux »
Turn signal and wiper stalk sold.
Clockspring sold.
Gumbeaux
Post by Gumbeaux »
Bump
