Winter Wheels & Tires for 98 V70 XC
superfeed
Year and Model: 1998 V70 XC
Post by superfeed »
Good People,
I hope you are all doing well.
I am trying to get some reasonable winter tires and wheels for my V70 and am evaluating my options.
There are some Momo wheels from a V60 available with nice Michelin tires, the sellers are motiviated.
Can my 98 V70 XC take a 215/50R17?
My stock rims are 15", but the sidewall ratio is lower on the 17's...
Thanks,
John Gregory
Portage, MI
Been thanked: 466 times
Post by cn90 »
Has thanked: 292 times
Been thanked: 765 times
They should fit but they are at the limit of what I like to do as far as speedometer difference. With the 17s the speedo will under-report by 5.2%, says you are going 70 but really you are going 73.5. The IPD page has all the info for center bore and offset, I think the offset difference would be OK but of course your best bet is to actually hear from someone who has used that wheel size.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
superfeed
Post by superfeed »
Thank you both very much for the responses.
From the IPD site, (if I did my calcultations correctly) I would increase my tire/wheel height from the center of the hub by 1 inch.
Depending on the actual offsets of the Momo wheel and my V70 XC rim, I could be increasing my displacement toward the outer fender by 0.275."
Sounds iffy... lol Maybe the seller would let me fit one.
Thanks!!
John Gregory
Portage, MI
superfeed
Post by superfeed »
Think I entered the wrong tire size for mine...
I have 205-65/R15.
I am considering 215-50/R17.
Increase in distance from hub center: 16.75" to 18.41"
superfeed
Post by superfeed »
I didn't smoke anything! Honest. lol
My little spreadsheet was wrong.
Looks like increase from hub center in wheel/tire height is negligible.
205-65/R15 = 12.75"
215-50/R17 = 12.73
Happy Holidays!
Has thanked: 1836 times
Been thanked: 1709 times
First check that the center bore of the hub is correct. Needs to be 65.1mm if I recall correctly. Some newer Volvos have smaller diameter.
I would suggest the best is to run the 15" diameter steel wheels and 195/65/15 tires as recommended by Volvo. Wider tires give less grip in snow.
