Would 1998 toyota camry rims/tires fit on a 1999 volvo s80?
caj767314922
- Year and Model: 2011Volvo
They are aftermarket rims and nokian tires. Just curious.
- Year and Model: Lots
- Been thanked: 128 times
Jaguar has the same pattern as Volvo though offset and bore size (centre hole) probably won't match being a RWD vehicle.
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
The Jaguar wheels don`t fit Volvo S80 because the offset is 60, while in the Volvo maximum is 49. So if you install Jaguar wheels you will have rubber contact on the fender and on suspension parts.
So for Volvo S80 (1999-2006) wheel and tire options:
Tire;
Diameters:15.00''-19.00''
Width(mm): 205-245
Tire aspect:35-65
Smallest tire: 205/65/R15
Biggest tire: 245/35/R19
Wheels;
Bolt pattern:5*108
Width(inches):6.5-9
Offset:35-49
Center bore:65.1 ( If center bore is bigger than 65.1 but other dimensions are as mentioned than those wheels can be fitted to your Volvo by using hub rings)
Tire;
Width(mm): 205-245
Tire aspect:35-65
Wheels;
Bolt pattern:5*108
Width(inches):6.5-9
Offset:35-49
