anyone using a big brake kit?
biohazrd76
Year and Model: 1997 850R
Post by biohazrd76 »
How much hassle are they, are you happy with them,modifications necessary? Have any of you simply swapped out for stainless lines what effect does this really have? My 97r will need all new brakes when I put it on the road, so I want to use something that will stop the car without trouble from a decent speed. Seems like everyone forgets about brakes when adding so much horsepower. I have seen the offerings from ipd but not much else, I am sure there are cheaper options. My 95 turbo had generic slotted and drilled rotors and some kind .Of indestructible ceramics that I would not use again....
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
It would be nice for the OP to put the URL of the said big brake kit so we know what the OP is talking about.
Before anyone jump in with 302mm brake upgrade, factory 302mm upgrade brake bracket are out of production, new or refurbished.
85 GLH, 367 whp
00 Insight, 72 mpg
biohazrd76
1997 850 R, black.
biohazrd76
This is just the bracket, at one point I thought they provided a kit with everything sorry.
1997 850 R, black.
Has thanked: 2199 times
Been thanked: 1852 times
Check on VolvoSpeed. I have read of a few guys who have upgraded to bigger brakes that are non-Volvo, but I think it may require machining or other mods.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
tryingbe
Post by tryingbe »
biohazrd76 wrote:This is just the bracket, at one point I thought they provided a kit with everything sorry.
Any only for the rear.
Try this.
http://www.vivaperformance.com/320mm-fr ... 0-s-c-v70/[/quote]
Yes, it's expensive. Since 8602456 and 8251319 302mm brake bracket is no longer available new or refurbished. You have very few and costly upgrade options for the front. I recently sold a set of used 302mm bracket for $200 + shipping. Wish I have more to sell. If you do find a set, GRAB THEM and you'll have a cheap 302mm upgrade option vs stock 280mm.
http://volvospeed.com/vs_forum/topic/16 ... continued/
85 GLH, 367 whp
00 Insight, 72 mpg
biohazrd76
Thanks for the link.
1997 850 R, black.
