Driving home yesterday I noticed warm air coming out of the passenger side vents. If I lower the password side temperature setting I get code air. If I set the driver and passenger side temperatures the same the passenger side it much warmer. Doing some searching I think the problem might be with the Cabin Climate Temperature Sensor. Recent when opening the door the little fan was making a lot of noise, now after this I noticed the fan no longer makes noise. I think it died.
The part is $150, so thoughts on how to test and confirm this is the problem? Or any other suggestion as to what might be wrong.
Cabin Climate Temperature Sensor/Fan
- Has thanked: 1506 times
- Been thanked: 3822 times
Try cleaning it with a vacuum flow first. They usually just gunk up with hair, dust, and detritus
- 10 Replies
- 11956 Views
Last post by wizechatmgr
- 1204 Views
Last post by 454cid
