Knocking noise comes and goes Topic is solved
jacie431
Year and Model: 2002 v70
Post by jacie431 »
I have a friend who offered to look at it later this evening. He said he has ramps. I told him I would buy him and his family pizza. If he can just get under there and take a look. I will report back tonight. And if anybody else has any ideas. Please leave them here.
jacie431
Post by jacie431 »
Fixed it!!!! It was a vacum hose under the car it runs to the back somewhere. It was unhooked. And sucking air in. Making a "puffing" "knocking" noise. I could put my finger over it. And it stopped. Hooked it back up. And no more noise! This was the simplest thing. And I was scared the motor was about to blow up. Thank you all for your help!!
MarcM
Year and Model: 2005 S60 2.5T AWD
Been thanked: 3 times
Post by MarcM »
Evap canister return line? Only thing I can think of that would draw a vacuum to anything in the back.
Glad you got it fixed!
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
Has thanked: 1609 times
Been thanked: 4064 times
Well done!! Isolating noises by hose is one of the best things I learned years ago, and as engine compartments got more cramped, it gets more useful. If your neighbors see you doing it, they do call the truck with the guys with butterfly nets though.
I listen to my old cars componemts when they aren't broken to get a sense of changes from stuff to help troubleshooting.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
How about a worn water pump allowing the the impeller blades to contact the casting?
