Coolant temperature always reads warm
marklawder
Year and Model: 1995 850
Post by marklawder »
So about a week ago I noticed the coolant temp was reading warm (3 oclock position) right away on a cold engine. I can let the car sit overnight and as soon as I put the key in, it runs right up to normal running temp without starting the engine. Thought this was the ECT sensor and I had a leaky radiator, so I didn't worry about it at the time. Just replaced the radiator today and swapped the ECT sensor and thermostat at the same time. Still having the same problem with the gauge. I tested both sensors for resistance and they both tested good based on the service manual resistance/temp chart. So I'm stumped. Got fresh coolant, new ECT sensor, new thermostat and problem was there with new/old radiators. Any ideas where to go next? What's weird is that most people say a bad ECT drives the gauge to full hot and mine is only halfway where it normally would be at temp.
dosbricks
Post by dosbricks »
What condition was the connector on the car where you plugged in the new ECT wires? The plastic is old and fragile and the brass connections can push backward in the connector and not onto the connector terminals on the new ECT. It may not be readily evident because that side of the connection faces downward.
Also did you replace with a genuine Volvo ECT?
marklawder
Connections looked brand new on both ends, but I cleaned it out with some alcohol and qtips while I had the sensor off. Both sensors are OEM volvo.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
One test that might help is to disconnect the ECT from the connector and then see if the temperature gauge still reads at 3 o'clock. If it does, then there may be a problem with the wiring from the connector to the gauge or the gauge itself.
marklawder
Yep goes right to 3 o clock with the sensor unplugged. Sounds like I need to pull the cluster and start checking wires, fun :shock:
Has thanked: 292 times
Been thanked: 765 times
Just curious: turbo or non-turbo? Mileage?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
marklawder
95 850 NA, about 200k miles
marklawder
Hooked up a scangauge and it's showing proper operating temperature from the ECT, reads from cold and warms up to the thermostat opening at 190F, so the sensor looks like its reporting OK to the ECU. Seems to be a connection issue behind the cluster, see video. Still not sure why the gauge shows 3 oclock when off and cold, but I don't really understand how it works really either.
https://www.youtube.com/watch?v=a-18gNf ... e=youtu.be
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 40 times
Been thanked: 28 times
Post by Cees Klumper »
Maybe it's the gauge that is broken ...
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
With vol-fcr or at a dealer you can read codes from instrument cluster.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
