98 s70 GLT Misfire
will do thank yall so much just woke up lol ... now is it hard to take off hahah sorry ... wont be tonight torandos everywhere tonight but ima sleep through them lol.. i rebuild transmissions but simple motor stuff idk about
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Do you have any new codes except for misfire?
Did you checked cap & rotor for wear and corrosion?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
No. Fuel filters don't get plugged up. Poor running is much more likely ignition problems on P80s, or fuel pump/relay problems, not filter.samtron6 wrote:do yall think it could be a stopped up fuel filter??? sometimes i give it gas and it seems like its not getting enough most of the time till i really get in it thanks
- misha
abscate wrote:...No. Fuel filters don't get plugged up....
Not to extend that fuel will not flow through it completelly,but it can restrict fuel flow.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
When people report "it feels like it isn't getting gas" the fuel filter is wrong 99.999% of the time...when they report it bogs down then clears and runs the fuel filter diagnosis is wrong 100% of the time.
- misha
Are cap & rotor Bosch or aftemarket?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
The last thing on the list is ignition coil.
It also could be a coincidence that something else failed in a time when you replaced plugs & wires.
Strange that there are no codes stored except misfiring ones.
Are wires properly clipped on cap and coil,also on spark plugs?
Is your GLT a light pressure turbo?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 19 Replies
- 10262 Views
Last post by Barledge
- 215 Views
- 952 Views
Last post by stephansvolvo
- 1644 Views
Last post by AD_NAPCO
- 2437 Views
Last post by jmorman
