Hi, looking for the fuel pump relay location for the 01'. I was able to find several other years s60 03 and 04. The under dash fuse panel on mine looks different than those.
I will try to include pic...found tab on left side of under dash fuse panel and was able to release it to take pic.
Thank you...
01' S60 non turbo Fuel relay location
Edengweiss
- Year and Model: 2001 s60
Here a pic...
- 20160318_151123-1024x576.jpg (168.89 KiB) Viewed 6353 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There is also a fuel pump controller on top of the right gas tank on models with the metal gas tank, known to corrode inside.
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
I found the following diagrams on the Web. My understanding is that your model/year isn't equipped with the fuel pump control module. As per the diagram, the relay (2/23) provides power to pump directly (6/33). It is located in position CMI12 of the CEM. It is the relay located on the left hand side of your pic.Edengweiss wrote:Hi, looking for the fuel pump relay location for the 01'. I was able to find several other years s60 03 and 04. The under dash fuse panel on mine looks different than those.
Hopes this help.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
Edengweiss
Thank you very much for pointing that out I will replace it as soon as I make it back to the car and let everyone know thank you
- 1058 Views
Last post by Ianmac22
- 4394 Views
Last post by WA-Boater
- 4102 Views
Last post by Lowmiles
- 743 Views
Last post by Ozark Lee
- 3230 Views
Last post by cajunxchange
