engine not turning p0342
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
2000 s80 engine cut out. tried to restart and it clicks like the engine is seized. battery is good. without pulling the timing cover off fully i was able to feel the belts tension which has a lot of play and the rear cam sprocket has play as well. I pulled the codes and it is showing misfire in #3 and the P0342. Any thoughts on where to start? I thought about compression test but the engine isnt turning over.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Has thanked: 1501 times
- Been thanked: 3812 times
If you can feel play in the timing belt it has broken and the engine has hit and bent the valves. It's probably stuck on one.
It isn't drive able and probably needs about 2k of head work to fix
stephansvolvo
That's what I was thinking. I was hoping to deliver better news.
I just didn't understand the clicking and at least not getting the typical turning over.
Thanks for your help.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo wrote:That's what I was thinking. I was hoping to deliver better news.
I think your last one got it...and it clicks like the engine is seized
Cuzimkenny
- Year and Model: 2002 s80 T6 twin tur
Timing belt shifted about 2mm.
Engine turns 3/4s the way with cams pulled out.
Indicating it's some thing in the lower end.
It dont think it would pass a fluid test, or a compression test.
Not sure if either were done though.
Could someone give me some insight, mechanic said I am looking at a new motor.
Around $4,600.00...
- 14 Replies
- 3816 Views
Last post by socals70
- 1764 Views
Last post by hermechanic
