Replaced AlternatorNow Electrical Problems
P80 Ignition Switch, Root Failure Analysis
I just replaced my alternator ( not charging)now its ok except now the power door locks don't function, the sun roofdoes not operate, the radiodoes not work and the reading lamps ( ones on the roof panelby the sunroof switch) also does not work. I checked all the fuses they are ok.Any ideas on where to go fromhere. Iappreciate any help.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
If, as it should have been, the battery was disconnected whilst you replaced the alternator then you have to re-calibrate some of the parts you are having trouble with.
The UEM may have some effect on the door locks and radio.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 2255 Views
Last post by chrisb315526
- 10 Replies
- 2032 Views
Last post by Faust
