Replaced AlternatorNow Electrical Problems
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
This topic is in the MVS Volvo Repair Database » P80 Ignition Switch, Root Failure Analysis
popps9
Post by popps9 »
I just replaced my alternator ( not charging)now its ok except now the power door locks don't function, the sun roofdoes not operate, the radiodoes not work and the reading lamps ( ones on the roof panelby the sunroof switch) also does not work. I checked all the fuses they are ok.Any ideas on where to go fromhere. Iappreciate any help.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If, as it should have been, the battery was disconnected whilst you replaced the alternator then you have to re-calibrate some of the parts you are having trouble with.
The UEM may have some effect on the door locks and radio.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
