Bosch MAF for 2006 S60
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Been thanked: 3 times
The number is embossed into the MAF. If you type in the Volvo # in Google, you'll find it. If you have the 2.5T, it's Bosch 0280218088. If it's the 2.4... Bosch 0280218089.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- Has thanked: 1505 times
- Been thanked: 3818 times
You can test the MAF by unplugging it, with the engine off,and then seeing if the rough running improves.
If it doesn't, you probably have a vacuum leak in one of the many hoses.
Replacing parts guided by engine codes without deeper diagnosis usually means you replace 2-3 good parts before you find Volvonirvana.
Whenever some reads your codes, get a look at the scanner and get the actual code...P1234 format. Snap a picture on your smart phone.
I'm in Boston area Tues Thurs this week if you want to risk a moderator isn't a serial stalker...PM me. Have code reader
MarcM
Me first for scan reader. LOL. In Derry, NH off exit 5 on 93 now, but car is where I said it was in my PM the other day.
Excellent advice on part swapping. A simple vacuum leak or bad ground somewhere can cascade across the systems.
2005 S60 2.5T AWD
IPD mods:
IPD mods:
Thank you for the excellent suggestions. Now I just have to pull out the volvo manual to see where the MAF is located. Stupidly, I didn't check this thread earlier when my son could have yanked it out for me. For some reason I thought I would get an email if anyone replied. DUH. I'll see if I can get my husband to figure out where it is so we can unplug it as that seems to be the first place to start. I'm hesitant to bring it to the dealer since they will charge me $119 just to read the code. They'll also probably present me with a $1000+ bill to try to fix it. : ) Mary Ellen
MarcM
Right off the air cleaner box. Not much fun getting the air tube off though. Twist and bend after loosening the airplane clamp. If the car is warm it will be easier.
It comes off with the two T-25's (if memory serves) that hold it to air cleaner top. The unit also contains not only the MAF, but the intake air sensor (IAT).
2005 S60 2.5T AWD
IPD mods:
IPD mods:
Abscate's amazing Boston traveling code reader will be in Boston again next Tuesday at MIT.
WIlling to divert reasonably to help out if I can still make it home reasonable hour.
Pm or EM best.
Pm or EM best.
- Year and Model: Lots
- Been thanked: 128 times
If your car is turbo you have the 0280218088.
If non turbo it depends on the engine management system. Up to 2004 they used Denso but after that not too sure. If it's a 0280218089 as MarcM stated they must have returned to Bosch for non turbos.
If you can provide a happy snap of your engine bay we'll narrow it down with our super Volvo parts indentifier program.
+1 on having the car read. There are air pressure sensors as well as air volume sensors in there.
