Seat Belt Tensioner
asummers
Year and Model: many
Re: Seat Belt Tensioner
Post by asummers »
Well, it looks like I will have to replace the tensioner as it is acting up again. I will hopefully find a used one locally. Thanks to all for the above advice. It will probably be closer to the first of the year before I can replace it. I will post about the experience.
_________________________________________________
1996 Volvo 850T Platinum Edition 170,000 miles
2000 Volvo S80 2.9 80,000 miles
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
You might want to try some silicon lubricant rather than WD40. WD40 is more of a solvent than a lubricant and from my experience it seems to evaporate quite quickly. Whereas silicone spray is actually a lubricant and will 'hang around' for a quite awhile.
Keep us informed as to how you make out....
asummers
Post by asummers »
Ok, so it has started acting up again. You have to yank on the belt to get it to advance the belt to the point that you can buckle it. I am going to put one of those baby seat tensioner things on it to hold it out so it doesn't take as long to get buckled up. Then I am going to start looking for a used drivers side tensioner.
Does anyone know if the tensioners are the same in the 2000 model S80, S60, V70, etc? Or is the same tensioner used across a few years?
__________________________________________________
1996 Volvo 850 Platinum Edition - 170,000
2000 Volvo S80 2.9 - 88,000
chattiniii
Year and Model: 1995 850 120000
Post by chattiniii »
After reading this and having the same problem, I sprayed my reel lock mechanism with break cleaner. It is now like new! Thanks! Chatty
