+1theWIFES_S70 wrote:Hey Rbaratt? How did your project turn out? Did you have to remove that rear mount to get the new lines in? I need to replace my rusted power steering lines soon... And have been searching high and low for a nicely detailed video, a la rspi!, but haven't found one. Also for a detailed tutorial with pictures. Haven't found that one either! If you were able to take any pictures, that would be immensely useful.Rbaratt wrote:I watched the video from Ben (FCP), on changing the mounts and noted that he leaves the front (I call it the front since it's on the front of the car) mounting bolt in loosely, before jacking the engine. He doesn't explain why, but I thought it might be to keep the bolt alignment from shifting, so followed that procedure.
If I could get the rear mount out, I'm fairly confident that I could get my power steering hoses installed. Just perplexed as to why I'm not getting the clearance I need?
How did it turn out Rbaratt?
