Speedometer reads 10kms fast.
57gretsch
Year and Model: 2005 XC90 T6
Post by 57gretsch »
Could this be something in the ABS controller?
I had to change out the original but the replacement was not in the list of part numbers for a 2000 V70XC.
The tires are correct. So they are not the culprit.
I noticed the descrepency when passing through a few speed monitors on the highway.
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
Has thanked: 1846 times
Been thanked: 1710 times
Do you still have the original? You can get them re-built fairly cheaply. Contact Matty at Mid-West.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
57gretsch wrote:...The tires are correct. So they are not the culprit.
What dimensions are they?
My car,for example,came from the factory with 205/50/16 on Persus wheels.
There were variations with 195/60/15...195/65/15 or 205/60/15,dependable of market.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
It isn't your abs module. More than likely it's the roadside radar deals that are off.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
57gretsch
Post by 57gretsch »
Didn't think so.
The tires are Spec according to the plate in the fuel access. Those are on Terra rims which are also Spec for the XC. I don't suppose deer whistles will defeat the radars
misha
Post by misha »
Matty Moo wrote:It isn't your abs module. More than likely it's the roadside radar deals that are off.
I think in that way too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Have someone follow you and check the speed in another car. If they are both out by 10kph then the radars are likely off!
ktuuri
Year and Model: 98 S70 T5
Post by ktuuri »
Borrow someones GPS and you will know for sure.
Matty Moo
Post by Matty Moo »
I always speed up when I see those in an attempt to set some sort of imaginary high score as long as it isn't in a residential area.
2000 s70 GLT
2014 Ram
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
In any car speedometers have a positive measurement deviation in about 5-8 percent. In this way manufacturers prevents drivers from exceeding speed limit. Also, there is a correction value for tyres size stored in instrument panel. Surely, this value should match to real tyres size.
If my English is bad, please correct me :oops:
