i have a 1997 v70 2.5 that won't start.
there is no spark on the plugs, and no fuel pressure. if i make a shortcut of the yellow main relay i can make the pump go. but still no spark.
tha car has a alarm installed, but the turning lights are not flash, no horn/siren is making noise and the little lamp on the dash board is not on.
where do the yellow relay gets its signal from? i do think it has something to do wit that, because the relay is not dragging when ignition is on, go when i attempt to start.
any ideas or maybe a circuit ?
regards and sorry for a bit bad english,
kent.
