1999 Volvo S70 Rear Bump Stops.
AhmedS70
Year and Model: 1999 Volvo S70
Post by AhmedS70 »
Hello guys
I had my rear shocks done on my 99 S70 about a week ago by this one private mechanic I found on Craigslist. He installed both of the shocks for $200. But he said that he could not install the bump stops. Are the bump stops really that hard to install. I took the car to a shop today and they said that they would charge me $300 labor to get both of them installed. I can see just my looking underneath that my old bump stops are totally worn out. Can the new shocks were prematurely if my bump stops are bad.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Piece of cake to install rear bump stops, given you don't have AWD.
I can probably do the job in 30 minutes. 15 minutes if on a lift.
Support the rear subframe, undo two nuts at the bottom of the shocks, undo two nuts for both springs, take the springs out, replace the bump stop inside the springs and then reinstall everything. Seriously, 4 nuts cost $300 labor... that's a ridiculous price.
85 GLH, 367 whp
00 Insight, 72 mpg
PS78
Year and Model: 2000 S70
Has thanked: 2 times
Been thanked: 3 times
Post by PS78 »
$200 dollars to install 2 rear shocks under the table is a ridiculous price too.
Always first off the line, while all the cool people are still staring at their phones.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I would say your mechanic finished the job and then realized he had forgotten the bump stops. There's an old trick to getting them to stick back up at the top if they ever fall down too- a bit of a pain, but it can be done.
tryingbe
Post by tryingbe »
PS78 wrote:$200 dollars to install 2 rear shocks under the table is a ridiculous price too.
You're right. There are two bolts and one nut per shock install. I can probably do the job in 15 minutes or less.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 311 times
Been thanked: 817 times
I totally agree, these are both simple jobs, can be done very cheaply and very well by a knowledgable DIYer.
Surely there is somebody in Chicagoland area who can help out the OP? Both vjaneczko and shaker_chi have been around MVS a long time: https://www.matthewsvolvosite.com/forums ... 34&t=43894, etc.
Stewart05
Year and Model: 1994 850
Post by Stewart05 »
MadeInJapan wrote: 02 Jul 2016, 19:51 I would say your mechanic finished the job and then realized he had forgotten the bump stops. There's an old trick to getting them to stick back up at the top if they ever fall down too- a bit of a pain, but it can be done.
One has gone off with de pin in perfect condition. Im ready for the pain. Please explain.
Thanks in advance.
manovlov
Has thanked: 673 times
Been thanked: 164 times
Post by manovlov »
It's a good way to start discovering your car. As said upper, 2 bolts in the car, 1 under, and that's it. I've replace mine last june. No special technical knowledge (to me) required, just a some wrenches. Also a good entry to create its own toolbox...
The proof in picture :
Manov
songzunhuang
Year and Model: 98 V70 T5
Been thanked: 30 times
Post by songzunhuang »
My car is a 1998 and I just did the bump stops. It was surprisingly easy.
First, here is what I saw when I went under the car to do some brake work. The stop had fallen and was just banging around the spring.
This is what I was dealing with
Bad stops.png (1.46 MiB) Viewed 1303 times
The new stop is easy to install once you get the spring off. Loosen the rear shock, remove the nut on the lower mount, and then you can lift out the spring. To install the new stop, I used a socket extension to bank on the pin of the clip, which expands the other side and fastens it.
Bang the pin
Bang the pin
New stop.png (1.24 MiB) Viewed 1303 times
Here's the new stop installed in the spring.
All good.
All good.
Stop Installed.png (1.3 MiB) Viewed 1303 times
Here's what got replaced. I'd say over 23 years is way beyond the expected lifespan. As you can also see, I replaced the rubber spring seats. May as well while I am doing this work.
Yea, time for new ones
These are toast.png (1.1 MiB) Viewed 1303 times
I think this took me all of an hour to do and I was going slow and taking pictures.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Great pictures and method! Thank you. In case it's of use to others who are thinking about doing this work, I replaced my bump stops a couple years ago and took some photos along the way: viewtopic.php?t=95813
