1998 s70 reverse jump polarity troubleshooting. Bad relays Topic is solved
Derbyrunner
- Year and Model: 1998 S70
Ok so I bought a running and driving 1998 S70 turbo and had to use a loaner battery to get it started and test drive. Car ran with no issues. Get it home and my teenage son who I bought car for hooked up new battery backwards. Now engine will not even turn over and the 15 amp fuse blows as soon as key is turned on. Need help badly
- Been thanked: 504 times
This has been reported before (reverse hookup), search forum for solutions, I think it is about checking a whole bunch of fuses.
This usually takes out the voltage regulator on the back of the alternator. Its actually good that it does this as this can get much more expensive than this.
Derbyrunner
Is there a way to test voltage regulator?abscate wrote:This usually takes out the voltage regulator on the back of the alternator. Its actually good that it does this as this can get much more expensive than this.
Derbyrunner
Changed voltage regulator and car still blows ignition fuse.
Ugh. You will have to find the right wiring diagram on the inter webs and trace that fuse and all circuits on it to find the fault.
Derbyrunner
Fuse number 10
Fuse #10 controls:
Ignition switch, Control modules - engine/automatic transmission 10 A
http://new.volvocars.com/ownersdocs/199 ... 70_102.htm
So it is down to:
1. A short in the wiring somewhere.
2. A short inside the ignition switch (which is extremely rare, almost unheard of).
3. A short inside the ECU, almost unheard of.
Please post a follow-up.
So it is down to:
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
That's the fuse that actually feeds the ignition switch itself.
From there it branches out to several things, including accessory
overload relays 105 and 106.
One way to deal with this is take a picture of the fuse box,
pull all of the other fuses and start putting them back one at
a time with the key on. Long way around, but it's a start.
This may help:
This may help:
