Yet again, 1990 740T Not Starting...
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
1990_740Turbo
Year and Model:
Post by 1990_740Turbo »
I recently took my 1990 740 Turbo to my mechanic (works on swedish cars) and he said I needed a System Relay. After the System Relay was put in, I went to pick it up. I drove it home, with no problems except for at one red light it started to stall for some reason. Besides that, there was no problems. I got home and tried to start it, and it wont now. I did the OBD and got back a 1-1-1 in socket 6 and a 2-3-2 in socket 2, which is supposedly something about the fuel trim or lamda control? Any help would be great, thanks again.
wojeepster
Year and Model:
Post by wojeepster »
see if you are getting 12v to the coil with the key on. On my 740 the wire is black/red. If not it is probably the electrical part of the ignition switch. they are a known failure item. If you have 12v to the coil with key on the problem lies elsewhere.
