850 Wagon wont start - possible 'limp mode'
misha
Has thanked: 152 times
Been thanked: 402 times
Re: 850 Wagon wont start - possible 'limp mode'
Post by misha »
Is the car turbo or natauraly aspirated?
Did you check timing belt area?
Lifters can cause ticking,not knocking.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Adsteph0408
Year and Model: 1995 850
Post by Adsteph0408 »
It is not a turbo. And we did check the timing belt, it's is in very good shape, it obviously had been replaced at some point.
misha
Post by misha »
Can you isolate where the knocking sound is coming from?
From inside the engine or outside?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Adsteph0408
It's coming from the engine compartment and most likely the engine. It runs real rough, and has very little power. All this started at a stop sign, car ran smooth and then I stopped at a stop sign and all of a sudden this loud knock noise started and it barely made it home. It was fine and then boom, it wasn't. Could it be misfiring?
Has thanked: 1505 times
Been thanked: 3818 times
You should probably run or have a compression test run on all 5 cylinders to rule out a head gasket problem
The loud noise could also be a broken exhaust manifold or something internal broken...bearing or. Connecting rod, but that's really rare on these cars
Adsteph0408
Just realized that the serpentine belt was really frayed. Also looks as if the timing belt might have "skipped" because we found pieces of the serp belt in the timing belt housing. Would huge misfiring be caused by bad timing?
misha
Post by misha »
If it skipped more than 2 teeth it bent some valves
Time for re-checking timing and possible compression test afterwards.
Bent valves should explain no power condition and loud knocking.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ugh.
