Fast flashing turnsignal on 98 S70
john200981
Year and Model:
Post by john200981 »
This one has got me. My left turn signal flashes 2 or 3 times as fast as the right one.
I thought that maybe one of the bulbs would be bad but both were ok...and even went as far as to replace with 2 known good ones. What gives? Turn Signal relay going bad or does someone else have an idea here?
Trilarry
Year and Model:
Post by Trilarry »
It's usually the turn signal relay getting ready to go south
Tri
98 S70 T5 225600 Miles as of January 17, 2009
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I've had this happen too when one of the bulbs is burned out...even one on the other side. Check all your blinking turn signal bulbs to see if you have one out.
john200981
Year and Model:
Thanks for the replies. All bulbs are good and work, so will go about and try another relay to see what happens.
john200981
Year and Model:
Trilarry wrote:It's usually the turn signal relay getting ready to go south
Tri
T,
What part of the hill country are you in? I'm between N.B. and San Antonio.
pfeener
Year and Model:
Post by pfeener »
It's a bulb. Take another look or swap out the bulbs. The relay doesn't know which side it's blinking for. If it's different from one side to the other, it's one of the bulbs.
john200981
Year and Model:
pfeener wrote:It's a bulb. Take another look or swap out the bulbs. The relay doesn't know which side it's blinking for. If it's different from one side to the other, it's one of the bulbs.
I have tried 4 different bulbs both front and back. No difference.
pfeener
Year and Model:
Post by pfeener »
Strange. The only other thing I can think of is to swap bulbs side for side and see if it makes any difference.
Trilarry
Year and Model:
Post by Trilarry »
Tri
T,
North of Boerne between Sisterdale and Kendalia, Welcome Neighbor :wink:
john200981
Year and Model:
pfeener wrote:Strange. The only other thing I can think of is to swap bulbs side for side and see if it makes any difference.
OK everyone, mystery solved. Fast flashing on the left turn signal was caused by a faulty socket. I had to take my voltmeter and put across the terminals and there just wasn't anything happening all the time. AND on top of that, the dashboard indicator that would show a burned out bulb did not indicate a burned out bulb either...so, got another socket from a yard and wired it in. Works great now.
