Volvo 850 reculation valve help
Ok so i am in the process of putting a recirculation valve on my 1997 850 t5. I was just wondering where the best place to put the outlet for the discharged air in the intake pipe before the mass airflow sensor or after. I know the maf on these vehicles are picky and i have heard on other cars guy doing it after the sensor but im not sure. So if anyone could chime in and let me know that would be great! Also yes by doing this i am deleting my cbv.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Are you sure? Wouldn't that meter already metered air again?beigg wrote:before is where you want it.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
That is how it was meant to be understood.Sommerfeldt wrote:Are you sure? Wouldn't that meter already metered air again?beigg wrote:before is where you want it.
- S
I believe we both understand the intent of what to do with the air, but the wording is catching us up here creating confusion.
You do not want to recharge the already spent air.
ugh smh 850 Turbo fridge
The reason im doing it is cause im running a manual boost controller and already getting flutter from the stock cbv. With a bigger turbo injectors and some custom tuning i am hoping to see around 300 hp. The factory cbv has been known to fail under high boost conditions i dont see a problem replacing it with a better quality one made to hold more pressure. it will be doing the same job as the factory one just more suited for my application. So plumb it before the maf?
Sommerfeldt
No, before the MAF would be between air filter and MAF. After the MAF would be between turbo and MAF. In this system, wouldn't discharging the air before MAF metering make for inconsistencies? I'd think that plumbing it in after the MAF, i.e. between MAF and turbo, like the line on the TCV, would be the way to go?beigg wrote:That is how it was meant to be understood.Sommerfeldt wrote:Are you sure? Wouldn't that meter already metered air again?beigg wrote:before is where you want it.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 292 times
- Been thanked: 765 times
LOL hard to get a straight answer sometimes, OP?
The factory CBV discharges into the intake manifold.
So basically "after." After the MAF, after the snorkel pipe, after everything but the intake valves.
The air is metered by the MAF, then charged/boosted, but because the boost is too high some air is dumped off the turbo instead of into the intercooler. Wouldn't make sense to boost that dumped air again (though you could I suppose), boost is already too high, so just send it along to the end of the whole intake system: to the intake manifold.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
