2005 V70NAM56 CATHERINE 496197 Manual 5 into code A981 Saurus 15inch wheels
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 1500 times
Been thanked: 3812 times
Contact Yagger for Volvo Module Programming
Color code 466 Barents Blue metallic
Engine number
83000- 88000
No oil consumption
Replaced both low beam headlights H11
28 mpg combined, 33 mph highway
New air filter at 85k
Reset service indicator
Resetting Volvo service light P2s
KEY IN IGNITION, TURN TO 1ST POSITION
HOLD DOWN TRIP RESET BUTTON (DO NO LET GO)
TURN KEY TO 2ND POSITION DO NOT LET GO OF THE TRIP BUTTON
AFTER A COUPLE OF SECONDS THE ORANGE TRIANGLE SHOULD FLASH
LET GO OF THE RESET BUTTON AND PRESS ONCE
Oil filter change
Air filter change
90050 miles, Jan 2015
Cabin filter chamged to 1.5 inch activated carbon
95000 miles
https://www.matthewsvolvosite.com/forums ... 87#p371087
97500 oil filter change with Mobil 1 SYN 0W-40
Tailight failure, both sides
Diagnosed and repaired
https://www.matthewsvolvosite.com/forums ... =9&t=73056
Timing belt tensioner idler changed, 99750
Turned heated seats up with VIDA
Turned off auto locking
Programmed three keys for kids
31 mpg at 70-75mph on Mobil 93 octane
Im pounding this one, Jim
Coming up on the next oil change at 105k
ALB BUF ITH ALB all in one day, averaged 34 mpg on 93. This is obscene.
Oil and filter change at 105250
Thread on options for engine cover plate or splash shield
https://www.matthewsvolvosite.com/forums ... =9&t=77058
Three latent error codes
DDM-0030, DDM-0032 Rear View Mirror Pot errors - faulty signal
UEM-0004 siren comm error
CEM-8B01 Parking relay lamp signal too high - parking lights front are INOP
ECM-930C Clutch position signal faulty
cleared all.
Replaced clutch switch. Improper fitment, nub for clutch switch is deeply covered in carpet, nit visible nub on firewall. Switch should parallel clutch action when correct.
https://www.matthewsvolvosite.com/forums ... ch#p417190
Replaced last three original ignition coils
New three point spark plugs, Volvo brand
https://www.matthewsvolvosite.com/forums ... 58#p418858
Mileage 108500
Slight clutch slippage on steep hills
Only initiates on hard acceleration at 2000-2500 revs in 4 or 5 gear.
Dual mass flywheel $800, plate seal $200, 10 hours labor
