OK update time re REAR Brake Pads...
1. Factory Volvo pads were OK until thickness = 3-4mm, then started squealing louder than a school bus.
It is made by Roulunds (A Danish company), made in India.
2. I have had good luck with Autozone "Duralast Gold" pads. Note that Autozone usually offers 3 lines of products with increasing prices:
- "Basic" or Everlast.
- "Gold"...this is what I use in my Honda, zero problems.
- CMax, probably good too.
However, Autozone does not carry "Duralast Gold" for 1998 S70, so I bought the "Basic" version.
MKD31 type. What a disaster, it is loud like 3 school buses put together!
This happens even I used anti-squeal compound.
3. Just happened to be at junk yard and saw newish looking pads (with about thickness = 9mm), pulled them, they were Mintex. I paid $4 for this junk yard set.
Installed Mintex, zero squeal.
So, IMHO, Mintex is the ticket!
PS: Want some good laugh? The Autozone brake pad box says:
"Made in Mexico", then another part says
"Exported to Mexico, from the USA"....LOL!!!
Brake Pads that don't squeal
soxmartin70
- Year and Model: 1997 850 T5
I hate to put it this way, however, the BEST REAR Brake Pads for the Volvo 850/S70 is the Centric StopTech 309-00310.
They have the "half-shim" affixed to the Pad. The shims are identical to the OEM Volvo Set 272272 - yet better, because they're affixed to the Pad. Fyi: Any other Rear Pad that I've installed began to squeak before they required replacing.
That said, I most recently applied a very light coating of Permatex #80078 Aluminium Anti-Seize Lubricant to the face of the Piston & Pad contact points. Fyi: My calipers are original to my 1997 Volvo 850 T5 with 250k miles - so I applied the Lubricant as a further preventative measure.
I purchased these pads at RockAuto and, for what it's worth, I'm also a big fan of the Centric High Carbon rotors. In fact, I prefer them over any/every Brembo, Zimmerman & OEM Volvo - and that's going back nearly 20 years. Fyi: I am pretty much "OEM all the way", but for brake items.
On a parting & important note, the arrows (on the shims) are to be installed "pointed" in the direction of "forward rotation"! Yes... the "cut-out" section of the shim "faces/opens" down, towards the ground. I hope/trust that makes sense.
All the Best:)
All the Best:)
- Been thanked: 471 times
The REAR Mintex pads (New rotors from Zimmermann) were quiet for about 2 years, now it is noisy again. And since it is down to 2mm, I need to replace them anyway.
After reading some forums and amazon reviews saying Akebono pad is quiet, I settled for Akebono EUR541 ($36 on ebay etc.).
WRONG! Installed the Akebono (yes I use anti-squeal compound) and it is noisy for the last few days, even after I went on highway and did some "brake bedding" (a series of braking from 70 mph in the middle of nowhere).
So, I can only hope that the Akebono becomes quiet with time. I will give it a few weeks to settle down.
As a consolation, the Akebono was made in USA...lol.
PS: I think the root cause could be the "fixed caliper" design that does not allow the caliper to "flex" a bit here and there to conform to the piston angle.
The FRONT is floating caliper design and I never have squeal coming from the front!
- Has thanked: 292 times
- Been thanked: 765 times
You keep mentioning the compound but that is only a band-aid. I can't tell from your posts - are you using the factory half-shims or not?
In my experience, the rears do not squeal with the shims.
I've never gone so cheap-o as organic rear pads, but everything decent quality (semi-metallic or ceramic) has been fine when the shims are used.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1504 times
- Been thanked: 3817 times
My Jurids are squealing like a pen of pigs on the back. I can play Dixie on them.
It lets people know I've arrived, though.
I also have a 2005 XC90 2.5T, did the Parking Brake, REAR Brake last year with Jurid pads (ATE rotors made in China whatever it means).
If the school bus brake squeal loudness is 5/10, the XC90 rear brake squeal is 2/10, not very loud but it is there at 4-5 mph, just prior to a stop.
You can see the brake parts that I installed in my 2005 XC90 2.5T:
OK, so you're not using the factory shims. You might want to give them a try.
See the very first reply in this thread for more detail, from OzarkLee. The shims work great, Volvo part number 272272.
e.g. $12.50 at FCP https://www.fcpeuro.com/products/volvo- ... l-272272oe
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I did try the factory half shims a few years back. It didn't work.
Noisy as usual.
Do a google search and you will see this half shim is a debatable idea.
Noisy as usual.
OK, the half shim is a nice idea but after a few thousand miles, the pads no longer hit the rotor at the leading edge (of the pad).
It is now down to being flat w.r.t. to the half-shimmed position.
The MINTEX: was quiet for 2 years, zero squeal, then at 2mm depth remaining, it squeals.
This happens at 3-4 mph just prior to stopping. But if I stepped more on the break (heavy braking) the noise stops.
Not to deepen the mystery but go figure this out: ONLY Volvo (not BMW) and ONLY REAR noise!
I only use "brand-name" stuff:
- Rotors: Balo, Zimmermann, ATE and nothing else.
- REAR Pads: Jurid, Pagid, ATE, Volvo OEM, and Mintex only.
1998 BMW 528i: zero squeal during the last 10 years.
2006 BMW X5: zero squeal the last 2 years.
1998 S70: As mentioned, Mintex no noise last 2 years but last few weeks, noisy.
2005 XC90 2.5T: rear noise is very slight at 3-4 mph, especially during light braking.
So having 4 cars....my theory is....somehow Volvo brake hydraulic system puts more pressure (psi) into the FRONT > REAR, so the rear does not have enough psi, so the REAR pads don't have enough bite during light braking ---> squeal.
In contrast, BMW probably puts more psi in the REAR hydraulic circuit.
Just my conspiracy theory...
Go figure!
Go figure!
- 11 Replies
- 5172 Views
Last post by jreed
- 460 Views
Last post by Fish stick88
