It’s easy in theory but awkward in practice.
I think the throttle body cleaning instructions in VIDA have been written by a Swedish intern – it’s literally a few diagrams and one or two sentences and not enough to get the job done- just enough to scratch you head...
I ended up cleaning the throttle body. As the intake side is was spotless – but on the engine side it was filthy and covered in gunk.
Here’s a few tips to make life easier.
Tools:
1/4 drive ratchet with various extensions & sockets
Regular Torx bits
Screwdriver
Small spanner to suit Torx bit
Removal guide
1. For improved access:
- Remove the dipstick
- Remove the fixed fresh air inlet snorkel
- 2 x bolts as indicated (10mm?)
- 2 x retaining tabs at the front of the snorkel
- Twist & lift out
- Remove the flexible adapter to the airbox
- Twists off
- Remove the airbox elbow adapter
- Easier to remove the air filter & push out the elbow from the inside of the airbox
2. Loosen the hose clamp (socket or screwdriver)
- The OEM hose clamp won’t go anywhere, it’s clipped to the edge of the throttle body hose
3. Undo the two front Torx screws
- If room is tight, ditch the ratchet and use a small open-ended spanner on the Torx bit as shown
4. Undo the two back Torx screws (done by feel)
- 1/4 drive ratchet + 1.5 inch extension and the Torx bit worked for me
(Push the hose out the way)
(Remove the throttle body and unclip the wiring)
- Depress 2 x tabs on the connector and pull off
- Ensure you don’t lose the green silicon rubber gasket
5. Clean with throttle body cleaner and wipe with a lint free cloth
Also a good time to inspect/clean around the oil filter housing
6. Installation is reverse of removal, but make sure that:
The throttle body wiring is not kinked or twisted on installation
The throttle body seal is snug in the plenum chamber
Don’t over tighten the screws – VIDA says 10 Nm which is just about 7 1/2 Ft Lbs- it's very light (but how would you get a torque wrench in there! If concerned, practice on a bolt somewhere that doesn't matter to get a feel for 10 Nm...then get on it but easy).
All the fresh air snorkel parts are seated correctly
It didn't seem to need a cleaning but after it was done, I noticed a much smoother idle so I'm glad I did it!
