S60 2003 N/A weird engine shuts off
enriquepr21
Year and Model: 2003 S60
Post by enriquepr21 »
oragex wrote:Before it shuts down, does the rpm gauge drop below 700rmp? That might mean the throttle body is sticking, needs a cleaning around the butterfly valve in and out, easy to do on the non turbo.
But the fact you get the clock reset, means more of a shortcut somewhere. Not something typical on this car. Was the car in an accident?
Maybe look inside the ECM box, in front of the power steering reservoir. Maybe some electrical component is moving when braking, causing a some undue electrical contact.
It's strange the radio does reset. The clock will reset, but not the radio when the battery is disconnected. What would reset is the climate controls (go on automatic).
Thanks I'll clean the throttle body today. Could it also help cleaning the maf sensor?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
enriquepr21 wrote:
abscate wrote:Two things that can intermittently fail
Fuel pump relay
12 VDC to coils
The only way to troubleshoot a fault like this is to hook up a voltmeter to monitor supply to the power points while you drive the car, or try replacing the parts.
Thanks I'll check on that today, also what do you think about the rpms dropping to about 500 then back up to 700 when braking to a stop?
This exact thing was a dirty tb on mine. MAF cleaning
enriquepr21
oragex wrote:
Fuel pump relay
12 VDC to coils
Thanks so i just cleaned maf and throttle body which was quite dirty. Also cleaned connectors and terminals again and the car seems all right though the idle is now a bit higher at 800 rpm.. i will have to test it thoroughly to see if this fixed the issue
enriquepr21
oragex wrote:
Fuel pump relay
12 VDC to coils
When you cleaned the throttle body did you experience a bit higher rpm?
oragex
Post by oragex »
Mainly, the rpm was only dropping from 750rpm to 500rpm when slowing to a stop, then going right back to 750rpm.
enriquepr21
Fuel pump relay
12 VDC to coils
What about fuel pressure sensor? Any way to know if mine is bad? There was a recall i believe
oragex
Post by oragex »
You need Bosch 0261230109 or 0261230236 for your Non turbo. Look at the torx screw: if it's really rusted, the sensor might be old. I'm not sure if it can be tested in some way.
Also, but not related to your issue, having the non turbo, at the front of the air filter box is a thermostat for the intake air, which fails at 10 years old and causes high fuel consumption. See this video
enriquepr21
oragex wrote:You need Bosch 0261230109 or 0261230236 for your Non turbo. Look at the torx screw: if it's really rusted, the sensor might be old. I'm not sure if it can be tested in some way.
Amazingly helpful info, look what i found
Been thanked: 4069 times
Nice Enrique and orangex....that's the fuel pressure regulator on the end of the fuel rail. On P2 cars that controls fuel delivery of course
enriquepr21
Thanks, also if you see the picture of my air filter box, there's no other hoses connecting it to the assembly that sucks fresh air located above the grill. Could this be creating an unusual condition and possibly be the cause of my stalling issues?
