hello,
I have a brake warning light appear on cold start up but disappears after 20 minutes of driving. Any recommendations on how to address the situation?
New to Matthews and my first used XC70.
Cheers,
2004 XC70 braking warning light on cold start Topic is solved
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Check brake fluid level in master cylinder reservoir. The buoyancy of the float in the brake fluid increases when it warms in engine compartment. When the level is right on the threshold of warning it will do what you experience. Usually brake fluid can get that low from pads being worn down to the lower limit. If pads are ok then expect to find a leak somewhere.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Takes only Dot 4 synthetic fluid for European cars. Canadian tire has it in Certified brand.
- 16 Replies
- 9494 Views
Last post by MadeInJapan
- 3138 Views
Last post by nucci480
- 2342 Views
Last post by ggleavitt
- 1886 Views
Last post by MoVolvos
- 618 Views
Last post by bubisamongus
