'94 850 turbo instr panel readout for miles left in tank
can you calibrate or check the accuracy of the instr panel readout for approx miles left before gas tank empty? mine seems to not be accurate anymore. thanks
MadeInAmerica
- Year and Model:
Be careful running the tank low. For some reason on volvospeed there was a rash of fuel pumps dying when the tanks got real low.
'94 850 Turbo 160K Automatic
[Autometer Sport/Comp Boost Gauge][Silicone Vacuum Hoses][Walbro Fuel Pump][New OEM Torque Mount][Yokohama YK520][New PCV system+Air Intake Hose][Magnaflow Cat at 160K][Borla Pro XS Muffler 162K]
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I agree...especially in the summer....the fuel acts as a cooling device for the pump, not to mention the contaminants you run through it when the tank runs low. Get in the habit of filling up BEFORE the low fuel light comes on. You can still calculate your milage by knowing the size of your tank (18 gallons) vs. how much you used (it took to fill up).
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
No. The reading is variable depending on how, and where, you are driving the car.can you calibrate or check the accuracy of the instr panel readout for approx miles left before gas tank empty?
When I first bought my car. I filled the tank and the gauge told me I had enough fuel for 410 miles. My total journey was to be 380 miles, give or take a few. Most of it was on motorways sitting at 70mph in 5th gear. At the end of the journey I was showing enough fuel to do 150miles.
I always have, and still do, fill the tank after I have done about 200 miles. That journey was the exception to my rule. I trust neither that device nor fuel gauges.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
