2002 V70 XC. 215,000 miles.
I had control arms, inner and outer tie rods all replaced about 11months ago.
Car just failed inspection due to a "loose left front end".
Grabbing the wheel, there is a *very slight* amount of play on the front left, when pushing left to right (none noticeable top to bottom). Right front seems fine.
Inspection shop plus another shop said "inner tie rod needs to be replaced". Brought it back to the (3rd) shop that did the front end work last year.. they pulled the wheel off and were somehow able to isolate the tie rods... they said, tie rods look good, play looks to be coming from the steering rack (!).
Rack is a big job, so want to make sure I'm doing the right work here... any advice? I would expect if it was the rack that I would have the same play on both sides, not just the left... but maybe not?
Loose front end... 2002 V70 XC. 215,000 miles.
Reason: No "help" in titles please.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I'd be careful when garages jump to the 'steering rack' issue. Talking from own experience.
Do you know what brand were the parts used 1y ago? It is well known that several aftermarket suspension components barely last 1 yr
Other than that, I would look into the ball joints perhaps.
RE make, I believe the new tie rods were Meyle parts, but I can double check with the shop.
And I mis-spoke, front end work was done a little over two years ago now, November 2014. So I guess it is possible it is in fact the tie rod again... what's a good brand?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
what brands were used for these front ends? There is also a chance at these miles for the subframe to be loose. There are poly inserts for the sibrframe bushings that work great for tightening that up and they are not expensive.
@MadeInJapan is this what you're referring to?
https://www.ipdusa.com/products/8969/12 ... insert-kit
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
Yeah... The only thing transfers even more vibration to the cabin - the upper engine mount. Say goodbye to comfort.MadeInJapan wrote:There is also a chance at these miles for the subframe to be loose. There are poly inserts for the sibrframe bushings that work great for tightening that up and they are not expensive.
