Identify this bolt
THAI UNG
- Year and Model: 2007 V70 2.5T
- Been thanked: 4 times
Oh one more thing came to mind,check the passenger side drive shaft and see if the piece #3 that hold the shaft bearing #1 to the engine block still intact with no missing any bolt #4,#5...and good luck .
- image.jpeg (155.53 KiB) Viewed 1903 times
cmbfoto
- Year and Model: 99 S80 02 XC70
- Has thanked: 11 times
Will do thank you Thai.. The rain has stoped in Syracuse now we have snow. That bolt is a 12mm x 60mm the grade is 8.8. It's not a control arm bolt so I'm going to have to put the car on ramps. I'll check the axle bolts in a day or so.
Chris
Chris
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I too would have guessed the control arm bolt. It's too short to be the strut, and it's not the ball joint. Or the steering rack... Or the top of the strut. I would check the control arms on both sides, make sure all three (six) bolts are accounted for.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- Year and Model: Lots
- Been thanked: 128 times
Looks more like an engine to transmission mounting bolt which I've attached a photo of. It's the right thread size and length from what I can tell. You should have 10 of them in total going all the way around the engine. This is one of the long ones which there are roughly 4 if I'm correct.
- 2453 Views
Last post by Kazthebassman
- 12 Replies
- 3719 Views
Last post by JimBee
- 1346 Views
Last post by vtl
- 1247 Views
- 1048 Views
Last post by importCar
