Sunroof control module
Lukystriker
Year and Model: 1995 850 turbo
Post by Lukystriker »
Sunroof not working. Tested the switch and it's good. Unplugged the sunroof control module and there's power at the plug. Would this mean the module is bad? Is it a common thing
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Not common. If you lower the motor you should be able to slide it open by hand. If it doesn't open by hand, there is likely something stuck in the track, maybe a part of the sunroof.
Lukystriker
The motor is good. Already tested
