fuel pump 1980 244
fuel pump 1980 244
What the best way to check the pump after you have it out of the car? Done the "earth the wires" out bit but not sure if it has intermittent problem Thanks
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
All the tests I know for a fuel pump are done with it in the car. The fuel passing through the pump acts as a coolant. Run it for too long without fuel and you may do damage.
What are the symptoms that lead you to suspect the pump?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
i thought the same thing.. your better off doing a pressure test while the pump is being primed and running inline with fuel.
There are a few things you need to check prior to the fuel pump... perhaps tell us as Bill requested what it is thats happening to your car so we can give more advice!
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
Dead pump. rattle it and it works.billofdurham wrote:All the tests I know for a fuel pump are done with it in the car. The fuel passing through the pump acts as a coolant. Run it for too long without fuel and you may do damage.
Bill.
- billofdurham
The old test by rattle - forgot that one.
Bill.
Bill.
Previously:
Previously:
