DIY 2005 XC90 2.5T REAR BRAKE (PARKING BRAKE) OVERHAUL
2005 XC90 with 95K miles. Symptoms: squeaky rear brake during stop, also RR rotor lost a chunk of metal (see photos).
If you have done Parking Brake shoes before, this is similar to other Volvos. I wrote a DIY Parking Brake for 1998 S70 previously, info in forum.
Over the years, I have found that after 8-10y/80K+, the parking brake shoes delaminate, the friction material just simply falls off, perhaps due to trapped heat inside the drum portion of the rotor.
No matter what car you own, after some 8-10y/80K+, just do a brake overhaul.
PARTS:
- Purchased from autohausaz.com, rmeuropean.com and Volvo dealer in Lisle IL (See their website).
- ATE rotor: made in China
- Rear Brake Pads: Jurid made in India
- Parking Brake Shoes: Pagid made in Germany.
- New retainer springs, big spring, small spring from Volvo OEM. See photos for PNs.
So...my XC90 is now multi-ethnic lol...
- Oh, during adjustment, the adjuster clip (inside the cabin) fell into a black hole, fished for 1/2h with the telescopic magnet, no luck. So get an extra one PN 30683358, $2-$3 at dealer.
PROCEDURE:
- Safety is #1 concern, so when working on RR wheel, chock the LF wheel on both the fore and aft parts as shown. I am a minimalist, my garage is tight, although I can afford a 3-ton floor jack, I don’t want it simply b/c I don’t have space and also it is heavy at 70 lbs+. I have a trust-worthy 2-ton floor jack ($20 at Harbor Freight or Advance Auto)…I simply add 2 pieces of 2x10 lumber (SUV has high ground clearance, so the lumber pieces raise the floor jack up), some plumbing adaptor, piece of tire rubber as cushion and I am good to go.
- Place jackstand below the control arm as shown. Then I SLOWLY lower the jack a bit, as if to share the load so roughly 50% of jackstand and 50% on floor jack. Another way is to lower the floor jack and gently jack it up until it is snug against the jack point. Then give it 1-2 more pumps.
1. Two 13-mm bolts hold the caliper. Box wrench and hammer to get them off. During install, I add a bit of antiseize, then tighten the bolt by hand, then rubber hammer gently tapping it so the wrench rotates about 45 degrees on the clock. Have done this thingy for years and it works for me. Or you can use a torque wrench but fitting a torque wrench in a wheel well is challenging!
- Hang the caliper using a hook.
2. The 10-mm bolt holds the rotor in place. Once the 10-mm bolt is off, tap the rotor with a hammer to get it off. Release the Parking Brake first!!!
3. See the Parking Brake anatomy. When you compare this setup against the 1998 Volvo S70, the XC90 does not have the “star adjuster”. Instead, the adjuster on the XC90 is moved to a location at the console, from the driver’s right thigh looking down.
4. Use a pair of pliers to remove the small spring first (WEAR GOGGLES!).
The “retainer spring”, look at the new spring and you will see how it works. Basically once pressed in, the hook on the spring latches onto the slit in the wheel hub.
5. I greased the brake cable where it enters the hub (it is deep inside).
6. During assembly, I find my special brake pliers to be useless. Here is the trick, see the sequence I numbered…
#1. Bottom shoe first, use “retainer spring”, to lock it in place.
#2. Now hook the big spring to the bottom shoe and the top shoe using Vise-Grips to pull on the spring.
#2. Now pull on the upper shoe and seat it properly on the “Expander”.
#3. Install the rectangular thingy (this separates the top and bottom, shoes). I apply a tiny amount of grease at points where the shoes contact the Expander and the rectangular thingy, you don’t have to.
#4. Small spring can be done by fingers or pliers.
#5. Lastly, install the “retainer spring” on the top shoes.
Whatever you do, make sure the “retainer spring” sits properly.
NOTE the numbering sequence that works for me...
7. Install new rotor. Don’t forget the 10-mm bolt.
8. Now, using a brake caliper tool ($5 at auto parts store), compress the piston until it stops.
Then install new brake pads. I added a bit of anti-squeal compound where the pads meet the caliper or piston. Install the 13-mm bolts (I use a bit of anti-seize here). Once tightened by hand, I add another 45-degree turn on the wrench and call it a day. Or you can use torque wrench too.
9. Once all done, re-install wheels, lower the car, and tighten the lugs as spec. I just tighten by hand and give it a firm tug on all 5 lugs.
10. Don’t drive the car yet. This is b/c the system is not safe yet!!! During the compression of the piston, the pads are pushed back and are not in contact with the rotor!
- With engine off, gently press on the brake pedal about 1-2 inches (don’t push it too far down!).
- After some 8-10 strokes, you should have a firm brake pedal.
- Now test drive the vehicle.
PS: PARKING Brake adjustment is done via the adjuster near the console (driver right thigh looking down).
- Peel the carpet back, use a small screwdriver to lift the metal clip. Don't lose this clip and you will never find it, it is deep crevice underneath! Best is to place some rags etc. under the cable to catch the clip! If you lose it, no big deal, get new clip from dealer for $2-$3.
- Now, VIDA instruction is very retarded. Parking Brake should be firm after 2-5 clicks on the pedal. Mine was at 7 after the brake job. This works for me: once the clip is off, use the small screwdriver and pry the rod toward the FRONT of the car to tighten up the cable. This is almost similar to bicycle brake cable (but bicycle use an adjusting nut).
- Anyway, I lost the clip, and even without it, the rod stays in place.
That is it boys and girls...
DIY 2005 XC90 2.5T Rear Brake (Parking Brake) 31262874 Overhaul Topic is solved
DIY 2005 XC90 2.5T Rear Brake (Parking Brake) Overhaul
- Has thanked: 2856 times
- Been thanked: 1332 times
They're all showing up on my browser. Great writeup.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Impressive write-up. Installing the brake new brake shoes is very hard indeed. I found that placing the part '3' the last while having one of the shoes lowered from the drum worked the better.
I'd recommend not forcing the piston back, instead to release the bleeder - a good moment to flush some fluid, then pressing the piston and tighten the bleeder. Only issue is the rear bleeders are very fragile.
Perfect moment to check the wheel bearings for any roughness.
- Been thanked: 504 times
Update: found the clip!
Local dealer wanted $7.50 for this PN 30683358!!! Online is $3.
I spent 1/2h yesterday with the telescopic magnet, broke it and still could not find the clip.
Anyway, I suddenly remember I just replaced the seat belt buckle recently and did a write-up for that, which involves lifting up the driver seat.
No problem, removed the four (4) 13-mm bolts, no need to d/c battery, propped seat up, lifted carpet and found the famous clip.
In fact, with the driver seat propped up, re-inserting the clip is a piece of cake (with the seat in place, even if you move the seat rearward, it is a battle). So if you want an easier time, prop the seat up (add another 15 minutes or so, very easy), see the DIY below...
DIY 2005 XC90 Driver Seat Belt Buckle
https://www.matthewsvolvosite.com/forums ... hp?t=68396
This is what the clip looks like...
Swede Emotion
- Year and Model: 2007 XC90, 2005 V50
Nice write-up! I used your article to figure out some of the jack points on my 2007 XC90. The rear brake pad swap as a breeze. The area to get a ratchet in on the 7mm hex nut (for the caliper removal) was pretty darn tight, but it worked out well. I used a regular caliper piston retractor and put a pair of Bosch pads on. I'm kind of stunned that these vehicles don't have a low-pad sensor like my older BMWs did. The pads on my XC90 were at 2mm and weren't making a bit of noise. Surveillance is key!
2007 XC90 3.2 AWD
2005 V50 T5 AWD
2005 V50 T5 AWD
T5AUS
- Year and Model: 08 XC90V8 94 850T5
Fabulous write up CN9, the only thing I would add is that in the later models (mine is 2008) when it comes to adjusting the cable at the front console the thread at the front can not be leavered out as it's sealed and to tighten I just locked a pair of standard pliers around the metal sheaf at the front end just before it angles up to the cable size. I then used a 9 mm open spanner to lever the inner pipe forward by just levering onto the pliers and against the larger central tube behind. It might be necessary to place a fulcrum between pliers and spanner if there is a larger gap to cover.
1994 850 T5
2001 V70 T5 (Sold)
2008 XC90 V8
2001 V70 T5 (Sold)
2008 XC90 V8
ALF1
- Year and Model: XC90 2003 2.5
- Been thanked: 5 times
A local Independent just mentioned the parking brake shoes from Volvo sometimes have a flat spot half way across the arc, the purpose of which is get more brake pad surface onto the drum. I had just changed parking brake shoes that I bought at 1A Auto and the parking brake just doesn't seem to be adequate. He suggested that I grind down a flat spot on the brake shoes half way across the arc to accomplish the same thing. Has anyone else observed this?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
May be worth staying with blue box? Sounds like aftermarket is not the exact same. ..Just a thought. How many miles did the OEM pads last you.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
