Hi all,
Thought I would present my case here to see if anyone had a similar issue and if they fixed it. Starting about a week (23. December) ago I started the car up (cold start), and drove out of my neighborhood to a traffic light (<1 mile), and waited for the light to turn green. After being stopped for about 30 seconds, the RPMs dipped to under 500, lights came on the dash, and the car died. I couldn't get the car started again after numerous attempts. I could hear the fuel pumps turning on, and the starter would engage as the engine was trying to start, but it wouldn't actually turn-over. I ended up pushing the car back, and leaving it to sit. I tried going out to start it each day for about a week, no success.
Moving forward to today, 1. Jan, I go outside and the car starts just fine! I cautiously drive it around the parking lot, and it idles fine and drives fine. I even stop (while in Drive) for about a minute (multiple times) and the car is fine, idle normal. I have done this twice today, and it's okay, no problems.
So I am baffled as to what the problem is. Previous to this problem the car did over 6000 miles problem free in all weather conditions (excluding snow). I have read that it might be the Idle Air Control Valve, but I am not sure since the issue is so intermittent.
The work that I have done on the car in the past few months includes a new Crankshaft Position Sensor, new Bosch Plugs, Booggecord (spelling ?) wires, new Bosch distributor cap, and an oil change. Like I said the car has been trouble free for the past 600 miles, and I would like it to do another 6000 miles in the future.
Please let me know your thoughts. Thanks!
Vehicle Specification:
1994 Volvo 945 (wagon)
Engine: B230F, Regina Fuel System
Automatic Transmission
94 945 Regina Non-Turbo Intermittent Idle/Start Problem
billyduck91
- Year and Model: 1994 940
Bricks_and_boxcars
- Year and Model: 1990 764T
Those Regina no starts after what you describe sound much like the classic RSR death. That relay is prone to solder joint failure and yes it's easily repairable.
I didn't see a reference to it in your description though if you did check that my bad.
Do look and see if you can open the diag connector port and cycle the modes (like go from mode 1, get codes, mode 2, test mode, mode 3, manual test) on the fuel control computer. It's a Bendix box and from my experience is pretty reliable.
I've had this happen warm, the relay is the first place I head to. Sounds like you hit the rest of the major points.
- 3841 Views
Last post by lummert
- 1650 Views
Last post by pnkelly1
- 1998 Views
Last post by walczyk
- 311 Views
Last post by BlackBart
- 196 Views
Last post by volvolugnut
