ps pump went south Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
On our 95 854 the power steering pump went south today, leaking all over the place. My wife drove home for about a mile with little fluid in the reservoir and a groaning pump. What are the chances the rack and pinion survived? After refilling the reservoir the pump still groans and leaks fluid.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
More likely they survived -- if they weren't an additional source of leaks.
The rack will live without pressure just fine. It doesnt blow up without oil pressure like a transmission.
- Clemens
So, finally, I got all the parts (used pump, new pressure line o ring, 4 Quarts of ATF) and watchd Robert´s Video in order to tackle the job. Looks like the pump was not the culprit but the pressure line being lose. When I tried to unbolt the pressue line i felt that it was extremely easy to turn with the wrench. After close inspection i saw the old o-ring was pretty ugly. So i gave it a try, replace the o-ring and after some bleeding the old pump runs just fine.
I have no clue why that line came loose after 300.000 km and 21 years, but it was quite an easy fix. Let´s see how the alternator and AC pump hold up after being flooded with ATF (and rinsed with brake cleaner and water).
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Its good for them. It helps the electrons flow faster when they are coated in ATF, then the brake fluid helps them stop.
You will be fine.
You will be fine.
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
I have had that issue too once on a car that I hadn't messed with and once on one I changed the pump on- I replaced the oring with one made to resist acids and stuff- only one I could find and it has been fine-
dyn blin wrote: 05 Apr 2017, 09:03 Thanks abscate,I had almost forgotten about the Henway effect from auto shop class.
- 2137 Views
- 688 Views
Last post by apollo13
- 1046 Views
Last post by jmscdgn
- 386 Views
Last post by Iceman12596
- 29 Views
Last post by M0125
