In my 1999 V70 that I just bought, which has a 2004 or 2005 S60 T5 engine in it, I replaced the radiator and heater core, since they were both leaking.
When I drained the coolant, there was a bunch of silvery specks in it, looks like glitter. I think it is aluminum since it did not attract to a magnet.
I'm guessing either the previous owner used "stop leak" at some point (which has similar looking particles), or the water pump is going bad in some way. I flushed the coolant and am going to see if it comes back in the coming days.
I was told the engine has about 80K miles on it, and the water pump is original as far as I know.
Any other ideas on what the glitter could be from?
Glitter in coolant?
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
- Has thanked: 1611 times
- Been thanked: 4075 times
There is a lot of Al in these engines Bob.
I wouldn't worry about it too much - maybe drain a liter of coolant in a few months and see if it is still there? Ill bet it is gone.
The pumps on these cars are robust and last 200k miles. If the coolant isn't really crappy and dirty it has been maintained, and I would run the original pump until the timing belt is due or more.
Ok, thanks. I will continue to monitor it. We have two 850s and I have never seen this glitter in the coolant of their engines.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Mm. hopefully not metal particles. The original pump is solid, but a replacement non Volvo/Aisin/Hepu one is a ticking bomb. I can only see metal shavings coming from a water pump in the coolant, the only rotating metal thing that touches this fluid. Unless the coolant mixed with some transmission fluid inside a broken radiator.
The water pump is a Volvo pump (says Volvo on it). I'm guessing its the original pump. They previous owner who replaced the engine said he pulled it from a 2005 S60 T5 with about 70K on it.
Rethinking. You can get a quick answer by flushing it for 15 minutes, the filling it with just water, running it around town for 30 minutes, then checking the water for glitter.
So I replaced the water pump, flushed out the system repeatedly and the glitter keeps showing up in the coolant. I had already replaced the radiator and heater core as well.
So what's left? The only think I can think of that coolant flows through is the oil cooler and the turbo.
Any thoughts? What else could it be? Anything in the engine (head gasket or something worse)?
Stop leak residue is my best guess.
Check compression and check coolant, engine oil , and transmission dipsticks weekly.
If it isn't mixing, drive it and keep your 2 year coolant changes religiously
Did a compression test last night, was fine, 180, 178, 179, 174, 180. I guess I'll just drive it and hope for the best.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Hard particles in coolant work as abrasive. You get the hard particles (calcium...) with tap water or cheap low quality "distilled" water. The one I got in CVS measured 70 ppm vs 14 ppm that my aging reverse osmosis system gives. Coolant breaks down quickly if mixed with hard water, internal wear accelerates.
- 16 Replies
- 4513 Views
Last post by granite
- 9 Replies
- 4522 Views
Last post by rspi
- 13 Replies
- 7381 Views
Last post by Ozark Lee
- 4180 Views
Last post by MathalomuleM31
- 2894 Views
