Did you know? 🤔
2004 S80 T6 Ice White
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
June
Year and Model: 2004 S80 T6
Has thanked: 267 times
Been thanked: 144 times
United States of America
June
Re: 2004 S80 T6 Ice White
Post by June » Sat Mar 18, 2017 4:25 pm
12/29/16 miles 129,048
Again visiting family in Holliday FL I was due for a oil change. I just don't trust Furman Volvo of Holliday so I took her across the street to Karl Flammer Ford where 10w30 full synthetic was used and Volvo filter.
1 R84021 oil filter. $5.49
CQ940 [email protected]$6.49
Hazard material $3.50
Labor. $9.61
TOTAL. $74.02
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
June
Post by June » Sat Mar 18, 2017 4:56 pm
2/14/17 132,396 miles
Osteen Volvo
Oil change synthetic with tire rotation
$139.73
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Sat Mar 18, 2017 5:29 pm
3/17/17 134,067
I took her to Osteen Volvo with a clunk going into reverse after driving in drive, I also wanted new struts, springs, and related parts, and replace the starter cable.
Mechanic discovered the steering rack causing pop sound and main engine mount had play as well. I highly recommend replacing struts, springs, and related parts. The car drives like I remember it did around corners, over bumps, just night and day difference, also the front is a good inch and a half higher now. Wow am I pleased worth the $5100.00 price tag.
Steering gear has excessive play
1 36050286 steering gear $1382.29
1 30741950 steering shaft 97.32
1 969092 o ring 4.32
1 98120 o ring 11.38
Fluid 33.05
1 9461483 engine pad (mount) 186.31
1 9461483 stabilizer bar 217.14
Labor 1046.18
Parts 1931.81 Labor 1046.18 total $2977.99
Line 2
Replace struts and springs
2 8667253 shock absorber. $500.16
2 30683637 spring seat 122.40
2 9489363 spring 126.04
2 31201396 stop washer 26.72
2 31212191 roller 60.48
Labor 418.47
Parts 835.80 labor 418.47 total 1254.27
Line 3
Replace starter B+cable and lower part of engine compartment fuse box
1 9469762 battery cable $123.62
1 9494210 box
Labor 348.73
Parts 178.94 labor 348.73 total 527.67
Environmental fee 23.95
Total ticket
Parts 2946.55
Labor 1813.38
Environment fee 23.95
Total 4783.88
Tax 334.87
Total repair $5118.75
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Wed Apr 26, 2017 1:31 pm
3/26/17
134319 miles
Full synthetic oil change
Parts, labor $100.44
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Tue Jun 06, 2017 12:10 pm
April 21, 2017
136243 miles
Replacement radiator and attached hoses and transmission fluid exchange performed at Osteen Volvo my normal service shop.
Line 1
Replace radiator due to weeping seal between tank and core. Mechanic said not to worry that the damp spot would likely not cause trouble but I insisted the radiator and connected hoses be replaced and new coolant.
Labor 585.86
1 31319056 radiator 427.13
1 30680911 radiator hose 38.12
1 30680916 radiator hose 38.12
1 31439821 antifreeze 19.95
2 988030 hose clamps 18.24
2 988028 hose clamps 18.24
1 5901 radiator flush 25.05
Coolant system power flush labor 99.25
Parts 584.85 labor 685.11 total 1234.96
Line 2 Synthetic transmission flush
Labor 99.00
1 3124 synthetic atf 110.00
1 6600 BG transmission kit 27.95
Parts 137.95. Labor 99.00 total 236.95
Line 3 check pcv system
Mechanic found dipstick not sealing properly
Labor 0.00
2 978165 hose clamps 13.04
1 dipstick 50.99
Parts 64.03 labor 0.00. Total 64.03
Line 4 replace pollen filter per my request
Labor 49.00
1 30630752 pollen filter 40.76
Parts 40.76 labor 49.00 total 89.76
Total repair 1765.14
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Tue Jun 06, 2017 12:13 pm
Synthetic oil change with Valvolen 10w30
137,463 May 20, 2017
100.44
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Sat Oct 21, 2017 4:19 pm
June wrote:
Sun Aug 07, 2016 9:18 pm
March 14, 2016 109,293 miles
Line 1
10k service
CF5 fuel enhancer
ADV Formula MOA
5w30 Castrol Edge
Oil filter INS
Gasket
Line 2
Timing belt water pump ECT
Tooth belt kit
Coolant pump kit
Thermostat housing
Gasket
Bleeder hose
Antifreeze
Belt
Hose clamp
Line 3
36 General repair concerns
1 36050999 Control Arm
1 36051001 Control Arm
2 31212191 Roller
4-wheel alignment
1 989763 bulb
35 CVR ? I don't know what this is
A/C service (per my request to replace freon)
Line 4
Replace both axles
1 8251782 Axle shaft
1 8251781 Axle shaft
Grand total $4,651.59
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Sat Oct 21, 2017 4:21 pm
:twisted:
June wrote:
Sun Aug 07, 2016 10:10 pm
April 5, 2016 110,209 miles
Took it in as acceleration was not smooth on harder acceleration.
Shop determined bad turbo control valve was faulty and a break vacuum valve had popped off hose apparently due to high temperature under the hood. Also 6 clips had popped off of the front bumper due to a high parking stop.
1 31400692 switch
6 3541113 clip
1 30670448 Solenoid valve
Total $445.87
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Sat Oct 21, 2017 4:23 pm
June wrote:
Mon Aug 08, 2016 4:01 pm
April 15, 2016 111,412 miles
Took it in for the washer sprayers on the hood, one had popped up and a oil change. Also material covering the sunshade had started to fall. My mechanic noticed that the fuel door hinge had a crack.
Line 1
3 30655605 washer nozzle 15.77 total parts47.31
Labor 64.75
Line 2
1 31265160 hinge 20.69
Labor 38.85
Line 3
BG cleaning oil change.
1 205 fuel enhancer 9.95
1 115 ADV Formula MOA 9.95
1 1275810 oil filter 12.00
1 977751 gasket 1.00
Labor 60.65
1 530su6 Castrol Edge 5w30 43.30
Line 4
1 989829 bulb 27.30
2 968458 flange cap nut 2.87 total 5.74
Total bill $381.00
My Volvo cars owned
1996 960 ordered
June
June
Post by June » Sat Oct 21, 2017 4:26 pm
June wrote:
Mon Aug 08, 2016 4:05 pm
April 26, 2016 111,612
Took car in for replacement moonroof sunshade which was ordered at previous ticket
Line 1
1 39850620 Cover plate 622.48
Labor 194.24
Shop fee 23.95
Total bill 899.51
My Volvo cars owned
1996 960 ordered
