1998 v90 no start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
blomkvist
Year and Model: 1998 v90
1998 v90 no start
Post by blomkvist »
I have a 1998 volvo v90 and I need help.
The car started to run rough and I got codes p0300, p0304, p0305, p0306.
I found that two fuel injectors were stuck open, so I replaced all six and put it all toghether.
Now the car won't start!
I get 42 psi fuel pressure and I tested the injectors and they all work. I found oil in the throttle body/air manifold and all the way down to the air filter, I cleaned all the oil out.
I don't get any codes.
I'm thankful for any help and ideas
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
what is missing?
blomkvist
Post by blomkvist »
So I finally tested the compression on my car and found that all cylinders tested fine except for #6
It doesn't have any psi or less then 20 psi
Is it safe to assume that the intake valve on cylinder 6 is the problem.
I don't have the tool to do a leak down test but no compression and oil filling up the throttle body seems to me that the oil is getting pushed out for the throttle body.
