April showers are here. The new pair of Volvo wiper arms are fabulous.
I like comparing parts before installing. After the arms were fully seated. Ran it. Turned-off, and tighten the nut down 1/2 thread at a time to remove any wrinkle/shake on return. You should see it smooth out on third tightening.
Driver Side Windshield Wiper Arm
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
I may got with a new arm then. I just don't know.
What do people think of Volvo's new (to me) Volvo for Life Plan, in general that is?
Maybe I'll get my arm replaced by the dealer, so when the new one goes bad, they have to replace it for free! That might be something worth doing.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- dosbricks
- Been thanked: 4 times
The problem is caused by the angle of the shaft distorting (wiper motor housing twists with age) just as much as the weakening of the of the arm causing the wiper arm to change geometric s. Notice it is always the driver side arm that is the problem, not the passenger side where the motor mechanism/housing is more robust. So a new arm is not going to make the wiper system like new.
Grinding the nubs is a cheap, easy, even repeatable process--BTW, still on my original grind after two years. But if throwing money at a problem makes one feel better that is always ones prerogative.
viper69
True only driver side is the problem child. I thought someone else said that grinding it down is only a longer "solution"? If that's the case, I could have Volvo replace it, and w/their Volvo for Life program, they'd have to replace it for free forever.dosbricks wrote: 06 May 2017, 19:09 The problem is caused by the angle of the shaft distorting (wiper motor housing twists with age) just as much as the weakening of the of the arm causing the wiper arm to change geometric s. Notice it is always the driver side arm that is the problem, not the passenger side where the motor mechanism/housing is more robust. So a new arm is not going to make the wiper system like new.
Grinding the nubs is a cheap, easy, even repeatable process--BTW, still on my original grind after two years. But if throwing money at a problem makes one feel better that is always ones prerogative.![]()
For grinding, I still don't have a good idea of how much to grind despite looking the pictures and my car. I'm a visual learner and this is something I'd pick up by doing, not so much by reading.
Volvo 850 GLT 1995
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Don't bother to grind it,you will get nothing.I tried and it got worse than before.
All i said stands for flat wipers,standard ones are wiping excellent before and after grinding the arm.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
It's clear from reading the thread that grinding works for some people but not for others.misha wrote: 08 May 2017, 15:24Don't bother to grind it,you will get nothing.I tried and it got worse than before. ...
I never understand posts like this, they are strangely pretty common in the forums: even the most experienced people sometimes make statements that basically say "well I looked at one car, and this is what I saw, so it will always be that way ... " It's counter to the whole point of a forum, to listen to what other people have to say, have a conversation.
I think you're not alone on this. I would just dive in now. Start by grinding off a little bit, just a few mm. Observe the surfaces and how removing material should change the angle of the wiper blade. If that first pass does nothing then grind some more. Or if that fixes it or makes it worse, then stop.viper69 wrote: ... For grinding, I still don't have a good idea of how much to grind despite looking the pictures and my car. I'm a visual learner and this is something I'd pick up by doing, not so much by reading.
- Been thanked: 4067 times
On our camper forum, the funniest thread was the one about "Does cooking in your car create odors?"
50% of the posters insisted they could deep fry chicken and onions without having cooking odors in their car.
OT, I just finally got my driver arm wiper to wipe the whole WS without hitting the A pillar for the first time in 3 years.
- dosbricks
Just 1-2mm should do it. It only minutely changes the angle of the wiper arm against the windshield. What it does do is let the arm press against the windshield with slightly more force (depending on how much is ground off) resulting in a clean wipe.erikv11 wrote: 08 May 2017, 16:21It's clear from reading the thread that grinding works for some people but not for others.misha wrote: 08 May 2017, 15:24Don't bother to grind it,you will get nothing.I tried and it got worse than before. ...
xHeart
Grinding doesn't work on 1997 850.
Replace the arm, and enjoy the downpour while driving through the storm on I-35, OK - TX.
I can drive in April Showers year-round now.
