Is my head gasket bad?
Hi, I am new to Volvos and really owning a car at all. I just bought a 2001 Volvo v70 with 119 thousand miles. I noticed within a week of buying the car that the coolant levels were going down quickly but I didn't see any signs of a leak. One of the times the coolant level warning came on so I pulled over and opened the hood. The coolant was at the low level marking on the tank. I let the car sit for thirty minutes and checked again and the coolant level was back up. I drove the car home and had no obvious issues. Then this morning I checked the oil on the dip stick and it was sort of bubbly. I freaked out thinking it was the head gasket and went to smoke a cigarette and calm down. When I came back and checked the dip stick again it looked normal. Any insight?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Perhaps not a quick answer, but really the only way you'd find out is a compression test. Thing to know is these engines don't have hg issues, but then again even the best engine in the world would blew a hg if for some reason it gets to overheat. If the news aren't good, it's good to know a head gasket is not a small job on these cars, so it's better to return the car for a refund.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I don't know if these engines are the same as my older 4 banger volvo but I found a blown head gasket by putting the coolant overflow tube into a bottle of water and watching the bubbles as engine rpm increased, more bubbles with higher rpm means its blown.
Also NAPA sells "block tester" fluid, its very cheap, run the coolant overflow pipe through it ...the gasses will bubble up through the fluid, its blue and turns yellow if exh gases are present in the coolant, I think its $7 a qt. Test done on a cold engine...obviously.
Thats when I junked my old 740, still ran too.
Could also be as simple as an air pocket in the cooling system, burp the lines , also check the footwells for moisture under the mats.
And it could also just be nervousness of a first car.
- oragex
Normally these engine will burp by themselves after a coolant flush. The way they burp is the coolant level goes down after driving the car the first time. Then we just refill as needed. However, I haven't noticed the level to go up. The NAPA stuff may indeed be a good option
- 18 Replies
- 5851 Views
- 485 Views
Last post by erikv11
- 1031 Views
Last post by Ozark Lee
- 25 Replies
- 5353 Views
Last post by Gtin
- 4472 Views
Last post by volvolugnut
