SKF is fine for REAR.
For the Front, my SKF seal leaked after 2 years: see the Timing Belt thread, I updated info there.
So, for those reading this thread, get Corteco brand (check rmeuropean dot com or eeuroparts dot com), it is better than SKF.
DIY: 1998 V70 REAR Cam Seals using SKF 11809 9443310
- Has thanked: 292 times
- Been thanked: 765 times
I put in SKF front cam seals when I rebuilt the head on my NA 6 years ago, and they are still good. So if you already put them in there is hope ... but I agree with the latest group-think here at MVS, go with Corteco if you have a choice. People also used to have zero problems with SKF axle seals, that is no longer the case. Coreteco.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I just has some tools custom made to press these seals in. It even has a step to get them in the proper depth.
Usually not an issue with the rear cam seal, but the crank & front cam seals like to go in tight and roll the inner ID seal lip, toss the spring, and leak pretty bad. The pro's use a seal press, usually made of plastic. The ones I had made are aluminum.
You fit the seal on the tool, press the tool into the hole (use a washer and the bolt at the crank position), the tool stops when the seal is in far enough, then pull the tool back off. Fast and easy.
Really sucks pulling a timing belt back off if the seal gets damaged during installation and you have the pleasure of finding out when you start the car.
Ask me how I know...
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
I am going to replace intake rear cam seal. When I unscrew the 10mm bolt behind distributor rotor, will it move/turn the timing gear on the front cam side ? I had read many post related to rear cam seal replacement, but no one mentioned about that.
Thanks.
Thanks.
If the timing belt is still installed, the gear will not move.
If the timing belt is off, movement is possible but unlikely. You can just move it back if it does. When the crank is on the mark, the exhaust cam moves much more easily than the intake (distributor) cam.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 304 times
- Been thanked: 517 times
I didn't have a problem with the distributor, but I did turn the exhaust cam when I removed the cam position sensor. This was on a '99 with VVT though, so I'm sure that made it easier to turn. It turned back when I tightened the screw. Car started and is still running no problem, so timing wasn't affected.
- rspi
Contact rspi..
Timing would only be effected if you took the cam VVT hub or sprocket loose from the cam.bmdubya1198 wrote:I didn't have a problem with the distributor, but I did turn the exhaust cam when I removed the cam position sensor. This was on a '99 with VVT though, so I'm sure that made it easier to turn. It turned back when I tightened the screw. Car started and is still running no problem, so timing wasn't affected.
I bought elring from autozone for $5.00. They shipped it in from Fed Ex.
The same elring is on:
https://www.ipdusa.com/products/5840/11 ... shaft-seal
Is elring (vdp part #619612) (volvo part #9443310) the same as sfk 11809 the same as volvo 9443310?????
No. The Elring cam seals have mixed reviews: some people swear they are crap, some swear they are fine. But for sure they are not the same as SKF or Volvo.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
