I need one of these, anyone have a junkyard run coming up? I would even take two if you can get them, why not!
This is a retaining clip for the fold-down hinge on an 850 wagon rear seat bottom. V70 may or may not be the same, I can't check as that wagon is living in another state this summer. Here's what they look like:
The sedans do NOT have this part, it must come from a wagon.
WTB red safety clip, rear seat 850 wagon Topic is solved
- Has thanked: 293 times
- Been thanked: 766 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1507 times
- Been thanked: 3825 times
Eric...I'll check my 99 parts and advise.
- Has thanked: 1855 times
- Been thanked: 1714 times
V70 are the same. I'm going on vacation in a couple of days so I will check in with you on my return if you got one, if not I may have a spare seat I can remove a couple from.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
got a pair, they will be in the mail this week. Do you just need one set, or the other. Got my *** handed to me today, I will continue mortal combat with that beast tomorrow. Got the rear bumper, cluster and dashpad, and the calipers with 302 brackets, but I haven't quite liberated the struts or the 18T yet. The angle gear is right in the way of getting the oil drain line loose, then pull the CHRA, then get the buried manifold flange nut. Robert's video makes it look so easy!!
Current Volvos:
Key bit of info - thanks Neil.scot850 wrote: V70 are the same. I'm going on vacation in a couple of days so I will check in with you on my return if you got one, if not I may have a spare seat I can remove a couple from.
Great news, thanks so much for finding these! I will send you a PM.FLXC90 wrote: got a pair, they will be in the mail this week. Do you just need one set, or the other. ...
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Received - thank you, thank you!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
